Hi!
If i have a divx movie ripped in US lets say in format NTSC. If i convert it to dvd and put pal as standard does the movie "jump" a bit? Sometimes i can see the movie jump a bit. Do you think that the "jump/flicker" disapear if i convert to ntsc instead of pal??
I use DivxToDvd or WinAvi. Any other good convert proggs??
/Michael
Results 1 to 11 of 11
/DJ MAGIC
Ok, i read you. Any other sugg. ??
What do you think about convert it to ntsc instead?/DJ MAGIC -
Basically, there's no reason to convert from NTSC to PAL, as PAL equipment handles NTSC material just fine.
Jump/Flicker mostly comes from bad frame rate conversions. Avoid if possible.
/Mats -
Depends on the original framerate (23.976 or 29.97fps), which you haven't given us, and how you're converting it (don't use all-in-one apps if you want quality). -
If it is NTSC already, there's no conversion needed to make it NTSC, is there?
Just stick to the same TV system as the source thruout the processing, and you'll be fine.
/Mats -
ConvertXtoDVD improves upon DivxtoDVD by using pulldown for framerate changes, so the results are much smoother, however I have to agree with Mats - why change if you don't have to.
Read my blog here.
The ultimate conversion method
FitCD -> Avisynth -> multipass VBR video encoding with ProCoder or CCE -> AC3 audio encoding with Sound Forge -> authoring with DLP 2.1 or DVDWS2
10 minutes to set up, 4 hours to complete at 3+1 passes in CCE or a little faster with 2-pass VBR in ProCoder. Time includes basic menu build as well.Read my blog here.
Hehe, now you hi-tech
Ok, lets the the step below this one. Any sugg..?
Like No AC3, Just a convert and merge it with subtitle.
/Micke/DJ MAGIC -
ConvertXtoDVD. Does it all without you having to learn anything beyond a couple of buttons.
Read my blog here.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Would NTSC DivX play on PAL equipment?
By videoboy2008 in forum Newbie / General discussionsReplies: 4Last Post: 10th Apr 2008, 02:43 -
XVID/DIVX NTSC to PAL
By bilbonvidia in forum Video ConversionReplies: 14Last Post: 23rd Jan 2008, 23:13 -
Is DivX(Xvid) A Cure For NTSC/PAL?
By hech54 in forum Newbie / General discussionsReplies: 9Last Post: 6th Aug 2007, 12:13
