I'm using ConvertXtoDvd to burn to dvd's but I'm having problems with dovx movies
can any help I want to covert divx to mpeg or somthing else ?
Convertxtodvd supports divx. Any error msg when you import or converting? and if it is .divx try rename to .avi and import.
the problem is that it will play on my computer after burning but not on my dvd player it says no disk
How *did* you burn it, and what model is your player? There are many possibilities here. If the DVD plays on your PC, but not your player, either the DVD is not in the proper video DVD format, or your DVD does not support recordable media. Otherwise, you'll have to be specific.
I use ConvertXtoDvd to convert & burn it It works with other mpeg's & avi's just have this problem with the divx ones
Are you converting to NTSC or PAL? Your dvd player may only support NTSC.
Or just try some other all-in-one tool and see if it helps...click on Tools in the menu here to the left and click All-in-one DVD Converters.
DIVX Movie Converting?
By RecoveryTTA in forum Newbie / General discussionsReplies: 0Last Post: 22nd Sep 2010, 21:22 -
converting Divx to QT?
By rotuts in forum MacReplies: 3Last Post: 17th Jul 2008, 17:28 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 24th Feb 2008, 00:35 -
Converting DivX to HD
By CFCproductions in forum Video ConversionReplies: 6Last Post: 18th Jan 2008, 15:11 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48
