hi all
i downloaded some video clips and the frame rate of the vids are 24fps. is there anyway i can convert them to 25fps PAL as i want to put them onto dvd. i have tried converting them with canopous pro coder and the result comes out choppy. whats the best way i can convert these clips into PAL. Cheers
Hi-
There are 2 good ways to do it, and some lousy ways. One of the good ways is to speed up both the audio and video to 25fps length, and resize for PAL. AviSynth is the way to go for the video, by adding:
AssumeFPS(25)
to the script.
The other good way is to keep it at 24fps, meaning the audio doesn't have to be stretched, and to run the resulting 24fps 720x576 video through DGPulldown set for 24->25fps. AviSynth should also be used for the frameserving. I have no idea how to do this in Procoder. It's a piece of cake in other encoders. -
thanks for the info mate. i also have virtualdub and tmpgenc. would they be better then procoder?
stretching 25fps audio to 24fps with mkvmerge
By deejay.2001 in forum AudioReplies: 0Last Post: 26th Feb 2010, 12:29 -
Audio adjustment for 25fps to 24fps
By ranosb in forum Video ConversionReplies: 29Last Post: 12th Aug 2009, 21:17 -
24fps HD-MKV (H264/VC-1) to 25fps SD-MPEG2
By Nightwalker_z in forum Video ConversionReplies: 9Last Post: 27th Apr 2009, 10:31 -
25fps to 24fps
By manzico in forum ffmpegX general discussionReplies: 20Last Post: 7th Sep 2008, 23:33 -
PAL speed-up: 24fps to 25fps video, how?
By JoachimS in forum MacReplies: 16Last Post: 26th Oct 2007, 15:39
