what app to use to change mp3 freq from 22 to 44? thanks
Just about any audio editor that accepts MP3s, and quite a few video editors, VirtualDub comes to mind as one. And there are likely a few standalone audio encoder programs that can do it also. Belight is one encoder that's a gui for besweet encoder, another is besweetgui. They do MP3 fairly well.
If you want a nice freeware audio editor, Audacity can handle MP3 and do a whole lot more than just convert the sampling rate.
This all depends on what purpose you are converting the MP3 for. If it's for a video, maybe you want to convert it as you are working with the video, then VirtualDub is one option. With VD, you might want to install the Lame MP3 codec to get the most options. If it's for a MP3 audio CD, then there are other programs more specific to this type of use.
And you would have to re-encode the MP3 if you want to change the sample rate, AFAIK. -
Look into MediaCoder. I haven't used it, but it seems to be able to do batch encoding.
Change audio in mkv from mp3 to ac3
By gauche in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2011, 05:05 -
Audio freq response on various DVD speed settings? - HELP!
By will7370 in forum AudioReplies: 2Last Post: 12th Jul 2010, 15:05 -
Want to change a bunch of mp3 files to smaller bitrate
By happydog500 in forum AudioReplies: 6Last Post: 11th Aug 2009, 12:08 -
Encoding MP3 causes the sample length to CHANGE?
By Colmino in forum AudioReplies: 1Last Post: 26th Nov 2007, 20:00 -
How can i change an mp3 to a wav?
By pondleaping in forum AudioReplies: 7Last Post: 28th Jul 2007, 02:09
