I am using AutoGK, and converting a DVD to DivX. I am using DivX codec version 5.02. What's the best CLI to use, so i can use it on my Archos video player. The screen size is 160x120. Also, please include the best keyframe rate, too. thanx!
CLI as in Command Line Interface? Sounds like you are talking about something else. Oh yeah, DivX 5.x did let you add params like that. The only true cli divx would be dr. divx 2. The cli in DivX VfW doesn't count since you don't actually enter it at the command line.
If you want to play around with the codec settings, then I don't think AutoGK is the right app. -
If you want fine tuning and lots of control, try VirtualDub or VD Mod. VDM can accept VOBs directly. Or you could use VOB2MPG to convert the whole DVD video to one giant MPEG and drop it into VDM. Still, AutoGK works well.
For keyframe rate, it depends on what you want to do with the file. The default keyframe rate on the Xvid codec and Divx is every 300 frames. This is fine as long as you don't want to do frame accurate editing after encoding. I use DV for that as every frame is a keyframe.
I use FairUse Wizard for DVD to Xvid conversion most of the time, mainly because it's easy and the quality is good enough for occasional play on my laptop for long trips. With FairUse, you just rip with a program like DVD Fab Decrypter, then let FairUse do the rest. I haven't tried it with a smaller framesize.
CLI of BDinfo??
By RogerTango in forum Blu-ray RippingReplies: 3Last Post: 15th Oct 2011, 02:13 -
x264 CLI
By zammil in forum Video ConversionReplies: 16Last Post: 22nd Jan 2011, 11:22 -
Need help with .vob's + x264 cli
By Frost746 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2010, 21:14 -
CLI to XML
By eon_designs in forum Video ConversionReplies: 1Last Post: 29th Apr 2010, 10:50 -
3.0.0024 CLI error
By casperinmd in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 2nd May 2009, 17:15
