While checking my burned DVD's for editing errors I noticed the playback stop at a certain point. Thinking it was the cheapo memorex, I burnt another one and it stopped at the very same point. I then burnt it on a top of the line disc and it was fine. So question is, what would make it stop and then continue to play. It did not happen on the PC only the dvd player. I burned them at 8, 4 and 2 to check memory. A mystry. Edited on Premier 6.5 then to DVDLab to Imagburn.
Bunny
Originally Posted by ridgerunrbunny"Art is making something out of nothing and selling it." - Frank Zappa
Still problems. Burnt on Yudan discs at slowest speed possible. They pause at same spot twice but not the 3rd. I have two short films on one disc authored in dvdLab. No labels. Created in Premeire 6.5 no skipping until on disc. Sometimes only pauses once at one spot. The people buying them are reporting same. Stop skiping after 2nd or third play.
Quandry, big quandry. not good quandry. wanna cwy quandwy.
Bunny -
DVD-Lab is (or at least was, seen nothing to the contrary) not 100% compliant, so it's expected that some players will barf on the discs.
That is one of many possibilities.Want my help? Ask here! (not via PM!)
I think it does have something to do with DVD-Lab. I've done this today. Opened up the original .dal, and re-compiled the version of what was stalling into new and different folder, reburnt them and everything was fine. I think the ones that were stalling are the ones that were in old memory, saved in one dal file but changed in the hard drive file. Or was that the other way around?@!? Deffinitely a DVD-Lab thing. Bums me out that I had to contact buyers to find out if it might be one of theirs that had a stall in it.
But Memorex is still notorious for crappy discs
Even a broken clock is right twice a day. -
The only reason I was using memorex was to get rid of them. sample burns. Yudan is not crappy. And I have not had any problem as of yet since I started doubling up on the folders.
DVD Play Back
By rcoran in forum Portable VideoReplies: 1Last Post: 4th Oct 2009, 02:26 -
play back problems
By heyhi in forum DVD RippingReplies: 4Last Post: 10th Mar 2009, 11:12 -
upside down play back
By suomiaussie in forum Software PlayingReplies: 2Last Post: 14th May 2008, 13:22 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 20:03 -
Youtube .flv files quickly stop playing but will play past half way point
By video1312 in forum Software PlayingReplies: 1Last Post: 20th Sep 2007, 13:20
