  1. Im trying to get a 200 MB AVI video file to around a 60 MB .rm (or .wmv) file. Does anyone know the best way of doing this, or what the properties of getting something like is?
    The quality can be lost alittle bit, but I have subs on some, so it cant be overkill...
    Windows media encoder for WMV, set the bitrate and convert. Use a bitrate calculator to calculate the output size.
    RealAnime for RM....maybe a bit complex though...
    Sep 2006
    Cnanada
    Hi there,
    What if I want to do the opposite ie. convert a rmvb with Unicode to a AVI. I tried rename the folder and the file in English then use notebkook to script the convertion to fps=29.97 and AviSynth it to open in VirtualDubMod. It won't open but it can play in Media Player Classic.
  4. Mod Neophyte redwudz's Avatar
    USA
    HM, try SUPER. It might work. Unfortunately, RM and RMVB are proprietary formats and there's not a lot of programs that handle them besides the ones from Real.
    Jul 2006
    Australia
    redwudz is right.
    SUPER can convert avi to mp4 using x264
