Results 1 to 17 of 17
  1. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Ok, so I'm planing to buy a USB Video Grabber, but I'm not a expert in this subject, so I need help to decide what model and where shoul I buy it.
    And I don't really know how to work with this, can someone tell me, pleeeeease...
    Thanks.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
  3. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Don't you know anything a little bit cheaper, I was thinking to buy something around of the 60€ or 40GBP.
    Thanks.
  4. Member edDV's Avatar
    Mar 2004
    You will pay in frustration and time spent.
    More detail about your plans may help. What are you trying to do?
  5. Member PTsniper's Avatar
    Aug 2006
    Portugal
    But how does something like this works:
  6. Member edDV's Avatar
    Mar 2004
    Poorly except for minimal quality CIF 352x288.
  7. Member PTsniper's Avatar
    Aug 2006
    Portugal
    And don't know anything a little bit cheaper but with good quality just like Hauppauge WinTV PVR-usb2 but cheaper.
    Edit: I mean, I'm alreddy paying in frustration when i see this price (if I had a job I would buy it right a way, but I'm a minor )
  8. Member edDV's Avatar
    Mar 2004
    PVR-150 is an internal version of that family and is cheaper. Avoid the MCE version unless you have a MCE computer. The MCE version doesn't include the software you will need.
    http://froogle.google.com/froogle?q=PVR-150+PAL&hl=en&hs=zEj&lr=&safe=off&client=firef...oogle&ct=title
    The issues to consider for other products. Is your time worth spending more now to reduce future frustration and poor quality results?
    Or are you only wanting simple minimal quality that is OK for a computer window but poor on a TV?
  9. Member PTsniper's Avatar
    Aug 2006
    Portugal
    I have a DVD recorder, so I want something simple to record some TV programs when I'm on vacations or out of my house, and I want something external.
    P.S. I tought I could use something that I could connect to my TV, not my computer, so correct me if I'm wrong but I think the first suggestion you made to me was something that I nedded to connect to my computer.
  10. Member edDV's Avatar
    Mar 2004
    And why can't you use the DVD recorder that you already have?
  11. Member PTsniper's Avatar
    Aug 2006
    Portugal
    because I want something I can use When I'm out of home, something practice, that I can connect to a laptop to extract the recordings.
  12. Member edDV's Avatar
    Mar 2004
    OK then we have gone full circle back to the PVR USB2. It has a PAL tuner and video/audio inputs. It will hardware record a MPeg2 fle that can be played back on the laptop.
  13. Member PTsniper's Avatar
    Aug 2006
    Portugal
    lol,
    but my main question is: don't you know something with good quality and practice andddddddd cheaper than PVR USB2
  14. Member edDV's Avatar
    Mar 2004
    I've been assuming you want something that actually works. Experiment and report back.
  15. Member PTsniper's Avatar
    Aug 2006
    Portugal
    What? Sorry but I don't understand.
    Mar 2004
    Boise, ID
    In a nutshell, the PVR USB2 is the cheapest one that works. There are other more expensive ones that are also good, IE: Ulead makes a usb2 that is pretty good, but costs more... When you find a model that you think interests you, read some reviews and see what others think about it.
    Rob
  17. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Thanks,
    so thats the cheapest?
    Thanks, thats all I needed to know.
