C00D1199: Cannot play the file
Windows Media Player cannot play the file. You might encounter this error message for one of the following reasons:
The file type is not supported by the Player. For a list of file types (formats) that are supported by Windows Media Player, see Supported file types.
The file type is supported by the Player, but the file was compressed by using a codec that is not supported by the Player.
The file type is supported, but you are trying to play it in a way that is not supported by the Player. For example, you might have tried to drag a DVD file with a .vob extension from a DVD to the Windows Media Player icon. Or you might have tried to open a .vob file by clicking Open on the File menu.
You are trying to play one part of a multipart file. Use a newsreader or other program to combine the files, and then try again.
Error ID = 0xC00D1199, Condition ID = 0x00000000
It's strange because I do have windows media player 10 and divx codec and a dvd player.
Surely it's a codec problem.
However, the error messagereally makes me smile! Why didn't I thnk of using a news reader to join my AVIs?!?You are trying to play one part of a multipart file. Use a newsreader or other program to combine the files
/Mats -
this is way beyond me. I dont know how to join stuff together. it sounds like an incomplete file.
Well, you should know that, if anyone. And the error message - a slate message, covering all possible bases. Might as well had been:Originally Posted by jyeh74
Nothing that makes anyone any wiser.C00D1199: Cannot play the file
Windows Media Player cannot play the file. The reason for this could be just about anything from a bad file to sun spots. We simply have no idea.
/Mats
"codecavil" what's mean? when play that this message play appear
By 59d43 in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2011, 12:00 -
WMP11 plays .wmv, .avi, .3gp no problem but won't play .mpg?
By billman in forum Software PlayingReplies: 8Last Post: 8th Feb 2010, 18:19 -
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 02:12 -
Cheap device that will play AVI, WMV, MPG?
By videohalp in forum Media Center PC / MediaCentersReplies: 2Last Post: 18th May 2009, 22:32 -
cannot play DVD from my WMP11 (error message)
By leinan in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2007, 13:43
