Hi Guys Ive posted a couple of times on this subject in bits but im getting nowhere fast so let me start from the top...I know you guys are good
Im trying to convert a dv file (.dif) to an mpeg2 / 6MB / cbr lower field first!
its that strict...anyone got any ideas what i can do? im using ffmpeg with some success but the video jitters.
your help would be much appreciated!
Neil
Downloading gspot now!!!
The video jitters when played back through a mpeg-2 decoder board into an sdi video feed for broadcast.
The reason I need to keep 6mb per second CBR exactactly is compatability with an adobe premiere plugin used and I havent yet acheived that....soon as I get in tomorrow ill run this gspot test.
Cheers
Neil
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
