Hi Everyone!
I have a show with 15ep.i try to convert to dvd.One of ep.#2 i just can not rename (it says if i change the file name will unusable) the rest i can rename without any problem.Any help would be great THANKS SO MUCH in advance![]()
Results 1 to 10 of 10
Not sure if I understand. I assume you have 15 different files, one per episode. And I assume that one of the 15 files can not be renamed. How are they named now? Why renaming?
RegardsThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin). -
Originally Posted by ptr866
In Windows, under "My computer"/ View/ UNselect the box "hide file extensions for known file types". That should make things clearer. -
Hi AlanHK!
Under/my computer/view i can not find any box or anything near as you mention as above(i am using windows xp)THANKS
ps:i tried to change the file and it is unusable -
ptr866,
You can get to it from all your folders: (look on top)
Tools>Folder Options>View.
It's a check box in "Advanced Settings"
Good luck on the vid.The Devil`s always.....in the Details! -
Right-click on the file icon. Select "properties". Is "read only" ticked? If so, untick, now try renaming.
Otherwise, post a screenshot of this properties page and more may suggest itself. -
When you look at the file name, do you see ep2.avi or just ep2 ? If you don't see the .avi extension then you haven't set your view up correctly as instructed by earlier posts. If you can see the .avi extension, make sure you have that extension on your new file name as well.
Read my blog here.
Any software to rename file based on video properties? good question!
By thomseye in forum Newbie / General discussionsReplies: 10Last Post: 18th Oct 2012, 17:07 -
Help Rename Title !
By bk_mutante in forum AudioReplies: 0Last Post: 19th Dec 2011, 21:52 -
need file rename tool
By sigpop in forum Video ConversionReplies: 2Last Post: 11th Feb 2011, 20:28 -
Batch Video Rename
By powerplyer in forum Newbie / General discussionsReplies: 0Last Post: 15th Sep 2010, 17:36 -
How to rename a file when it is in ntfs mode
By mysts in forum ComputerReplies: 3Last Post: 19th Feb 2010, 04:34
