    Sep 2004
    Denmark
    Hej.
    I am using Nero burning rom 7, I would like to make an DVD with more than one movie, the files are video TS, how is it posible to do this.
    svaage
    Aug 2005
    Right here
    No matter what burning software you use, you can only burn one VIDEO_TS folder. So all the movies must be in this folder. You must author this way. With TDA by adding each movie as a different track. With DLP you can also add more than one movie. Then you can set chapters for the begining of each movie, and build the menus according to this. In any case, all into the same project. That way, at the end, you will have only one folder.
    Regards
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin).
