Results 1 to 11 of 11
    Jun 2005
    I know there are alot guides on splitting a dvd , but i cant find the right one, could have missed some too but here my prob ..
    i have this 7 gb dvd ... main movie is 4,46gb and the rest is 2,54gb ... sooo i have put them in separate folders , but not i need to fix the VTS stuff ... dont know how and i hope someone could help me out with that.. i have seen something about ifoedit but i cant figure it out ...
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    He's a liar and a murderer, and I say that with all due respect.
    Nov 2004
    Las Vegas
    The easiest way I can think of, using freeware only, would be to open the ripped disk in VobBlanker, blank out extras, etc., to get it the first disk down to single layer size. Save the result as disk1. Re-open the ripped disk with VobBlanker and reverse what is blanked, then save it as disk2. Even the menus should still work correctly.
    Even easier, but using payware, would be to use CloneDvd2. It has a very easy way to split disks in much the same way as the VobBlanker way, with less work.
    Jun 2005
    Awesome, awesome.. vobblanker worked like a charm... but now, how do i disable a button from the menu .. i remember there is an app i used for it .. you could see the whole menu.. and select "action" and change to what i should do ...
  5. Human j1d10t's Avatar
    Feb 2003
    California, USA
    "Don't try to be a great man. Just be a man, and let history make its own judgment."
    Zefram Cochrane
    2073
    Nov 2004
    Las Vegas
    Originally Posted by 0verd0ze
    ...how do i disable a button from the menu..
    Using freeware, your best bet would be the Menu Editor in PgcEdit. Right click the button you want to disable, click "Hide Button" - "Replace command with NOP".
    Jun 2005
    hmmm about splitting again ... i get errors when i open the vts in pgcedit, saying something about mismatch or something similiar ... which isnt good .. which is the proper way to split the dvd ? blank or skip ? and shouldnt VobBlanker "re-do the vts" ?
  8. Human j1d10t's Avatar
    Feb 2003
    California, USA
    Sometimes after I've used VOBBlanker I have to run FixVTS on the files. You might want to try that.
    I didn't even notice that you now have to pay for Menu Edit - I've still got the free version that I downloaded a couple of years ago....
    Zefram Cochrane
    2073
    Jun 2005
    Ok, i'll try that and see what happens , will post the results ...
    Nov 2004
    Las Vegas
    0verd0ze,
    When PgcEdit reports the error(s), does it offer to fix the error(s)? If it does, you should let it go ahead and fix whatever it wants. Then save, and test the dvd files to see if it works correctly.
    One of the very nice features of PgcEdit is that it does look for errors, and then offers to fix them. It's only when PgcEdit doesn't offer to fix the error that you have a problem, and even then it will give you suggestions on the best way to handle the problem.
    If PgcEdit says it can't fix the error(s), or the PgcEdit-fixed dvd files don't play correctly, please post back with what the problem is, preferably with either the exact wording of the error message(s), or screenshots of them.
    Jun 2005
    VegasBud,
    PgcEdit, "said" that when i opened the dvd, and gave me the popup-window with the white-red-cross saying that something is wrong, but i fixed that thanx to FixVTS.
    Once i opened the dvd again, it said something about audio, like "there are 18 audio tracks, but only one are in use" lbalba .
    "do you wanna fix lbalbla"
    so now everything works fine,
    thx to all of you
