Using DVDShrink I archived a DVD. Now after many plays, the disk cracked and I'm trying to burn a replacement. I generated an .iso using Imgtool and tried to burn it back onto a Double Layer DVD+R Using Nero. I get the message that it's the wrong disk type, that I need a -R. I can't find any DL -R's around here and mail order they only come in 3 packs.
Is there any way to change what I've got to be able to burn back onto DL +R's
Thanks.
Andrew
Results 1 to 9 of 9
Use DVDDecrypter instead....straight to an .ISO and burn with same?
Will either/both work from the Video TS folders files since the orginal disk is FUBAR'd
Originally Posted by ap.sand"Art is making something out of nothing and selling it." - Frank Zappa
Most people here are responding to the fact that:
1) It shouldn't matter about +r to -r or vise versa.
2) DVDShrink is not the best or most efficient way to do a straight copy of an already un-encrypted DVD since it lacks a built-in burning engine like DVDDecrypter. -
ap.sand,
Yes, ImgBurn in "Build" mode works directly from the VIDEO_TS folder. Just use Windows Explorer (or My Computer) to copy the directories (VIDEO_TS and AUDIO_TS) from the cracked backup to an empty directory on your hard drive, then use ImgBurn (in "Build" mode) to write the directories to a new dvd blank.
This guide will help you with the ImgBurn "Build" mode process, in a convenient step by step tutorial. -
Tried it last night. It gave a error about "reached the end of user area" as it was writting the lead out. With a quick look this morning, the disk seems to work anyway. We'll watch it this weekend to see if it was fully successful.
Thanks again for all the help, you guys are great!
Changing DVD Frame rate
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 28th Dec 2011, 19:58 -
Changing date on finalised DVD
By rosbif08 in forum SubtitleReplies: 7Last Post: 8th Nov 2010, 13:49 -
Changing the Order of audio on a DVD
By PBoy in forum EditingReplies: 5Last Post: 15th Aug 2008, 00:02 -
Changing DVD Title Name
By richards2222 in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 02:26 -
Changing DVD audio
By 557953 in forum EditingReplies: 3Last Post: 29th Aug 2007, 08:14
