  1. I*ve made the transision to my MacPro and over all it went very smoothly
    its well worth for all to keep there eye on one of these $$$$ permiting
    I went from two G4duals one my fathers and one mine to this
    I almost got a variety of G5's but waited
    I consider myself very lucky
    now the questions: is iMovieHD the "iMovie 6" and it does all that imovie 4 did? is there any need for iMovie 4 as thats still on my computer?
    cheers and thanks for all the continued help
    rotuts
    MPro 2.66 3GB RAM 1.5TB HD's
    MigliaMiniHD
    QTPro, MPEG2 add on MPlayerX2
    MPEG Streamclip
    24 + 21" samsung flat panels
    G4dual 2GB
    AlchemyDVR card
    Oct 2003
    Canada
    You don't need iMovie 4 anymore on the Mac Pro - it's a PPC app anyway.
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    you'll need it to finalize any hanging projects.
    Once you open the projects in iMovieHD,
    they won't open in any other iMovie.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  4. Ill keep it in the Apps out of the dock
    Ive started using iMovie HD and it no longer segments into 9 minute chunks
    those made it easy to time line and edit
    Ill have to scrouge for the imove 6 book now!
    spend more on the books than the comp as the books keep adding up!
    cheers and thanks
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
