  1. Ok I've been backing up DVD's for a long time, I've got over 1,000 DVD back-ups. I'm running 3 programs: DVD Shrink, DVD Decrypter & DVD Fab Decrypter. Now I'm having a problem with a couple of the discs of House Season 2. I used DVD Shrink which anylised fine, but encountered a problem (which happens from time to time) shrinking it. So I used DVD Fab Decrypter to copy to computer (which worked perfectly as normal) then tried DVD shrink again, but again same problem. So I tried DVD Decrypter then DVD Shrink but yet again same problem. Is anyone having this problem burning House Season 2? Or can anyone give me some advice? Thank You Very Much for your time
    I'd rather die on my feet.
    Than die on my knees.
    Aug 2002
    cleveland, oh
    Try ripit4me
  3. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    Yep, change to another encoder, it's quite clear that shrinks the problem and not your ripping software.
    I Have Always Been Here
    Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H
    Nov 2004
    Las Vegas
    slipknotkod,
    DvdShrink chokes if you give it a bad rip. If you'll follow the suggestion made by jameshgross (rip with RipIt4Me), your DvdShrink problem will go away.
  5. Thank You guys so much LOL now I can finally watch the episodes I've missed ^^
