    Jan 2005
    boston
    I'm trying to copy a DVD onto my computer, and Dvd Decrypter can't seem to do that for me. I've tried copying this DVD before, and it didn't work then, so I got a different one, this one doesn't work either.
    Here is the main part of it. It shows one read error and a bunch of retries.
    http://img.photobucket.com/albums/v215/pete_rock/dvddecrypter.jpg
    Here is the log
    http://img.photobucket.com/albums/v215/pete_rock/log.jpg
    and here is the error that pops up
    http://img.photobucket.com/albums/v215/pete_rock/error.jpg
    And ideas on what I'm doing wrong?
    Thanks ahead.
    Nov 2004
    Las Vegas
    peterock,
    That error can be caused by a dirty or scratched disk, or it can be caused by one of the newer copy protections. Since this is the second disk with the same problem, it's most likely DvdDecrypter is being thwarted by a copy protection method that came out after work on DvdDecrypter was discontinued.
    You should try RipIt4Me to rip the disk. It assists DvdDecrypter by generating a PSL2 file for the rip, and cleans up the internal mess after ripping.
    Post back with details if you run into any problems.
    Jan 2005
    boston
    That worked perfectly, thank you very much.
