I need to edit some real media files. What's a good editor for Real Media files?
since it is a crap format ,, you will have to really convert them first to avi ..
then any editor will work
dont expect to much in terms of quality"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You could try REVE. It's freeware, so you don't have much to lose. But Real is a proprietary format and not a lot of editing options are available. And most highly compressed video like Real is difficult to edit anyway. After you re-encode them, especially after extensive editing, there may not be much quality left.
Unless you really have to work in that format, there are better options with similar quality for their file size. -
One other that I know of is on the Real site, but it's pretty basic: http://service.real.com/help/videoccg/editing.html
There is also the AVS editor, but it's payware: http://appcraft.org/shop.php?pid=45&kid=46&detail=1024
RealVideo was not really made to be edited. I usually convert it to DV or some low compression format and edit it with VirtualDub.
The Zwei-Stein Video Editor 3.01 might be able to handle the format. It's freeware and has a graphical interface and quite a few features: http://www.tucows.com/preview/195042
Demuxing WMV using Windows Media Stream Editor
By Bully9 in forum EditingReplies: 11Last Post: 19th Mar 2013, 16:43 -
VideoPad Video Editor narration/media problems *PLEASE HELP*
By 19tyler19 in forum EditingReplies: 1Last Post: 25th May 2011, 01:04 -
Windows media stream editor tutorial?
By branch in forum EditingReplies: 1Last Post: 13th Dec 2009, 20:10 -
Converting Real Media
By KLouis22 in forum Video ConversionReplies: 2Last Post: 29th May 2009, 16:47 -
real media to avi help
By odiedog in forum Video ConversionReplies: 5Last Post: 18th Jan 2009, 05:10
