Hi all,
Well, it seems to be a silly question, but I'm a bit confused.
I have a DVD that has been recorded on a stand-alone recorder in 16:9 PAL format, it has no menus.
So, I used DVD Decrypter in IFO mode to retrieve the MPG muxed stream and now I just want to import it onto Maestro or Adobe Encore. As far as I understand, the 16:9 flag is written on the head of the file, OK ?
Is there anything I must do on the authoring sw so it'll properly recognize the file is 16:9 ?
Has DVD decrypter possibly unflagged the header to 4:3 ?
May I write click on the Maestro setting to specify it's a 16:9 or should I just don't care if Maestro is set to 4:3 ?
I have a similar question about PAL to NTSC conversion i'll post at the right forum now,
Thanks,
Zetti
Originally Posted by guns1inger
Cheers,
Zetti
A Mac tool that can author .mpg to DVD folder for buring
By Sam0403 in forum Authoring (DVD)Replies: 5Last Post: 5th Mar 2012, 14:49 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
