Karen Navratil here, I have been recording DVDs on my computer which contain
AVI movies. Each DVD has about 5 to 6 movies. They play great in my Lite-On
Recorder hooked to my TV! However none of the movies has it's title showing so
I can select the movie I want to see. I have to preview each movie before I
find the right movie. The file names on the DVD have the Titles. What am
I doing wrong? - Tks much - Karen
Just starting into video and having very hard time!!
You need to have a ultra divx certified dvd player to do menus for divx. I don't believe liteon has a model like that.
The only other way to do menus for them would be to convert each movie to mpeg2 and then author a regular dvd.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Most dvd players that support divx playback, will open the disc to a file list screen. It will then list the files on the disc for you to choose. Sounds like your model doesn't list the files.
Google is your Friend -
Or you could try ConvertXToDVD2 by VSO software. It will convert all the AVI files with menu to a readable DVD by any player you have.
Works with the ones I have. -
My old LiteOn 2002 has a setting where you can elect to have it give a file list when you put a disk in, or just start playing the first file. It's called "ISO Disk Autoplay".
The Philips DVD642 will do the same thing. The setting is simply called disc menu (on/off).Originally Posted by jagaboGoogle is your Friend
How to create Superman titles
By prizi in forum EditingReplies: 35Last Post: 1st Jan 2013, 15:52 -
Looking for a program that allows you to create titles like this?
By juliejwl777 in forum EditingReplies: 3Last Post: 23rd Aug 2011, 08:56 -
Looking for free DVD video editor that will create chapters & titles
By Brent G. in forum EditingReplies: 1Last Post: 22nd Feb 2009, 02:25 -
Showing Movies & copyright laws
By pepegot1 in forum Newbie / General discussionsReplies: 13Last Post: 12th Sep 2007, 17:57 -
Showing a series of titles on a DVD?
By Balliol in forum Authoring (VCD/SVCD)Replies: 10Last Post: 21st Jul 2007, 06:53
