    Mar 2005
    Toronto
    Okay, I have Dave Chapelle Standup DVD of What its worth and killin them softly.
    I ripped using ifo mode of DVD Decrypter. Now i want to convert both of them to the highest quality xvid possible to use maximum room on my dvd (regular 4.35g dvd) for both of the files.
    Id prefer keeping the subs. I've been using AutoGK but it doesn't seem to output as I have hoped, (they dont wrk on my DVP-642) Any idea what i need to do?
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I *think* there's a couple of options in the hidden section (Hit Ctrl-F9) to help with standalone compatibility.
    If in doubt, Google it.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, I think so too - IIRC, it's the ESS Vibratto Chipset compatibility you should use.
    You could also try avi.net - does pretty much the same thing AutoGK does, but taking a slightly different road.
    /Mats
  4. Yep, reinstall AutoGK, this time using the ESS chipset option. You can do it a video encode at a time using the Hidden Options, but you might as well get it set up correctly.
    Mar 2005
    Toronto
    ill try again with teh EEC or w/e
    Mar 2005
    Toronto
    I used Avi.net it worked great thank you
