when i create an image from video_ts folder w/imgburn it creates an .iso file and an .mds file. i am using imgburn to burn the .iso file. what is the .mds file? should i be loading i instead? my dvds seem to play fine. thanks.
A MDS file is a small meta file that contains description information about the associated ISO.
This file is used by several different programs. It generally is found with an .ISO CD image file and is the equivalent of what a .CUE file is to a .BIN image. IsoBuster can interpret these files directly.
You can just ignore it for what you are doing.
.mds (image file) to .mkv conversion - how ?
By shuq in forum Video ConversionReplies: 1Last Post: 29th Jul 2010, 08:30 -
Why Does ImgBurn Only Sometimes Build an MDS File with ISO File?
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 13th Aug 2009, 23:36 -
Need help converting an .MDS file into a .VOB file can anyone help??
By casper1910 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2009, 04:08 -
Help me! I can't play file *.mds file after i 'mount image' using daemon
By i_nui in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 13:04 -
Creating mds file
By StoryDonut in forum Newbie / General discussionsReplies: 2Last Post: 9th May 2007, 08:12
