Every time I encode an avi to dvd using CCE, I always get the error message, when authoring that the combined bitrate is too high. I have my audio at 224 ac3 and here's a sample of my avs script.
AviSource("E:\movie.avi", false)
ConvertToYUY2()
LanczosResize(720,476)
AddBorders(0,2,0,2)
ResampleAudio(44100)
using 4 pass vbr with minimum bitrate @ 2000
maximum '' @ 8500
average " @ 5500
avi length is 124 minutes
I'm using CCC 2.70
if I try to lower the maximum bitrate it make no difference.
My bitrate calculations say that for a 124 minute video with a single 224kbps audio track, the average video bitrate should be 4686kbps. This also allows for 20mb of space for menus. An average of 5500 kbps allows for 107 minutes.
Your calculations are cactus. It is the average that you need to adjust, not the maximum, as this is what CCE is trying to match.Read my blog here.
Too high an average will result in a file that won't fit on the media. But it shouldn't have any effect on the max bitrate.
soundforbjt: Make sure you do not have the DVD Compliant option enabled in CCE. This tags the stream with a nominal bitrate flag of 9800kbits for the video. This often results in it being viewed as having a much higher bitrate by authoring software. Its just a misapplied flag (in my opinion) so you can ignore it if your software lets you. There's really no point in using the dvd compliant option in CCE unless you need a quick and dirty way to adjust resolution to compliant settings.
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Is the bitrate high enough?
By Weef in forum DVD RippingReplies: 23Last Post: 25th Jun 2009, 10:29 -
Caching files with high bitrate?
By therock003 in forum Software PlayingReplies: 5Last Post: 15th Dec 2008, 17:54 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54 -
Mpeg2 artifacts at ~high bitrate.
By ronkkrop in forum LinuxReplies: 24Last Post: 13th Apr 2008, 15:06
