    Jun 2006
    Planet Earth
    Hi, silly question , but I look on Adobe premiere help, and premiere menu but couldn't find a way to remove old project. Can I just delete the files that created by the project? It is eating up my harddisk resource!
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    You mean the "Adobe Premiere Preview Files" on your scratch disk?
    Those are all the temp files that were rendered for format conversions, transitions, filters and audio.
    Yes they can be deleted when you have finished the project. The entire directory can be deleted. Separately save the project file and it can regenerate the temp files given enough time and the same input files.
    http://www.kiva.org/about
    Jun 2006
    Planet Earth
    Thanks, I think so (preview), it resides in 'my document' folder. So I just delete the folder from windows explorer?
  4. Member edDV's Avatar
    Mar 2004
    yes
