Hi all......im hoping someone might be able to shed some light on my little problem.
I am backing up an AVI file onto DVD. I have converted it with Cucusoft Mpeg/Mov/RMVB/Divx/AVI to DVD/VCD/SVCD Converter Pro and the resulting file is of good qaulity and plays back pefectly on my computer
The only problem is that when burnt to a Verbatim DVD disk and played back on my pioneer stand alone DVD player the sound keeps cutting in and out, or is jumping for lack of a better word, whilst the video is still of good quality.
The DVD files have been burnt to disc with both the Cucusoft Mpeg/Mov/RMVB/Divx/AVI to DVD/VCD/SVCD Converter Pro internal burning program and with Nero7 with the same result.
I have successfuly backed up other avi files without this problem and am dumb founded why this has happened. I am assuming that its not a codec problem by the fact that the converted DVD file plays back ok on my computer. I am also assumming that the DVD media is not the problem as it hasn't been a problem in the past.
Any light that can be shed on this problem would be appreciated.
Mako71
First, you are not actually "backing up" the file to DVD. You are converting and avi to DVD format. If you are backing it up to dvd, then you would just burn it as data.
Second, is the file playing fine on the pc before or after the conversion (or both)?
I would expect it is an issue with your conversion process. Possibly a corrupt file, something in the file is causing your software to choke, or audio output does not meet dvd spec.
There is a small chance it is media, but media issues usually also result in choppy video.Google is your Friend
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
stand alone software
By mtdg in forum Newbie / General discussionsReplies: 3Last Post: 25th Nov 2008, 00:52 -
Will my stand alone DVD Player provide 5.1 for my surround sound?
By dc01039 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Aug 2008, 02:14 -
rmvb stand alone?
By noob4ever in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Mar 2008, 03:18 -
DVD sound is terrible played back on stand alone players
By nikoz in forum Capturing and VCRReplies: 0Last Post: 12th May 2007, 18:13
