I have a color problem with Hauppage PVR USB2.
THe Color default setting is too bright for capturing, so I reduced the brightness level to the closest to the original. But at this setting, my monitor displays the image a little too dark for my liking. The problem is that WinTV2000 is not capable of storing several Color Profile like Winfast PVR software, ex, for viewing on monitor & recording. This creates a problem for me because I can not create a setting that will look good both in my monitor & my capture. So far, the only thing I can do , is to take note of each setting for viewing & recording, and manually adjust them each time. This is not practical at all.
Is there any possible solution ?
Doesn't anyone have similar problem with the color adjustment ?
I read in the forum that I can sharpen the picture with registry tweak,
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Globespan\Parameters\ivac15\Driver]
"SharpnessValue"=dword:00000007
But frankly, I don't see any effect on the picture, nor my recording. Is this tweaking also applicable to PVR USB2 ?
Is it supposed to bring changes on both monitor & capture at the same time ?
In Hauppage Tweak Tool, the 150/500 Tab ((Brightness, Contrast, Saturation, Hue, Sharpness) seems to have option to set "Capture Filter" & WinTV2000 independantly.
[img=http://img133.imagevenue.com/loc308/th_23532_7_122_308lo.jpg][img=http://img21.imagevenue.com/loc432/th_23544_9_122_432lo.jpg][img=http://img155.imagevenue.com/loc365/th_23552_11_122_365lo.jpg][img=http://img24.imagevenue.com/loc378/th_23562_14_122_378lo.jpg]
[img=http://img155.imagevenue.com/loc322/th_23571_htt_122_322lo.jpg]
What do you think about the image ? Is it really that bad ?
I find it too dark, especially in dark scene, it can get really fuzzy & hard to see.
Results 1 to 1 of 1
Hauppage HD PVR
By xX-Towrd01-Xx in forum Capturing and VCRReplies: 6Last Post: 19th Mar 2012, 16:15 -
Hauppage HD PVR or Colossus?
By yearofthespider2k3 in forum DVB / IPTVReplies: 10Last Post: 18th Apr 2011, 20:16 -
Converting Hi8 for Mac using Hauppage WinTV PVR USB2?
By eamann in forum MacReplies: 7Last Post: 6th Aug 2009, 15:37 -
Hauppage Windows PVR
By Trollheart in forum Media Center PC / MediaCentersReplies: 6Last Post: 21st Apr 2008, 19:25 -
Annoyance with Hauppage Soft PVR
By DB83 in forum Capturing and VCRReplies: 3Last Post: 20th Dec 2007, 11:00
