More Information. The program bombed on File 4 before.
I convert the movie that SVCD2DVD had the error on before from 640 x 480 to 720 x 480 in another program first. Then I tried to have SVCD2DVD convert the old movie (640 x 480) and the stretched version (720 x 480) into a DVD as follows:
1- First without the Pan and Scan Info Box Checked. SVCD2DVD worked without a problem.
2- Second WITH the Pan and Scan Info Box Checked. SVCD2DVD bombed with the same error. It passed through the stretched version but bombed on the original 640 x 480 version.
I have attached both the log files for these conversions into ONE big log.
I hope this helps you compare the two logs I have combined into one big log.
svcd2dvdlog-20060903two%20conversions.txt
Here is GSpot Info of the Movie 640 x 480 without stretching that caused the problem for SVCD2DVD
gspot%20movie%20640%20x%20480.zip -
ok. Firstly pan & scan is only a suitable option for SVCD resolution files. i.e. 480 width. There is no need to do it on your files. 640 x 480 is not a valid DVD resolution and thus needs to be converted to 720 or 352 (width) first. You have done this so i would now proceed as normal but miss out the scan & pan option.
Where Does This Video Information Come From?
By hech54 in forum Software PlayingReplies: 5Last Post: 3rd Apr 2012, 12:51 -
US Video CD information?
By phatrat1982 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jun 2011, 23:07 -
h264 information?
By orangeboy70 in forum Newbie / General discussionsReplies: 0Last Post: 26th Mar 2011, 19:04 -
Full Information Media Problem
By cyberlion in forum Newbie / General discussionsReplies: 6Last Post: 16th Jul 2010, 11:43 -
File information
By TyWelcome in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2007, 14:52
