Hi all,
I am new at this game, and am wondering how to up the volume in an AVI.
Then using TMPGenc and Nero to produce VCD.
I am using DVD2AVI, and the sound track on the resulting AVI is very quiet.
Whilst I appreciate this can not be done in DVD2AVI, has anyone got any recommendations please.
Many thanks in advance
<font size=-1>[ This Message was edited by: The_Apprentice on 2002-01-11 07:39:09 ]</font>
use audio effect filter in advanced in tmpgenc.
If that dont help, export to wav file then import in Sonic Foundry's Stream anywhere and EQ the file then save as an asf file. Use that and encode that to mp2 or mpg audio file
ShiZZZoN PzN
Everyday is another payday and I am one step closer to becoming the one. -
i usually use DeDynamic.exe
you can probably search and find this.
it's a command line tool though, so a typical line would be like so:
C:\Dedynamix.exe -a 6 your_input.wav your_output.wav
where '6' is the increase in decibels i think.
anyhow, this has ALWAYS worked for me, the sound gets a great boost with no clipping (distortion at the high levels).
just make sure you pick 44.1KHz when it asks you.
hope this helps!
Cheers~
JCPicache
Increase a video's volume?
By AVT in forum AudioReplies: 1Last Post: 10th Sep 2008, 02:41 -
How to increase Volume in FLAC
By sureshforum in forum AudioReplies: 4Last Post: 13th Feb 2008, 09:23 -
volume increase
By natty in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2008, 10:08 -
how to increase the volume of the audio?
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 05:45 -
Increase Audio Volume?
By ambrosechapel in forum ffmpegX general discussionReplies: 6Last Post: 7th Nov 2007, 08:05
