I'm trying to do 2 things:
1. Convert 2 images (in the form of a slideshow) to an mpeg2 file (m2v? mpv?). It's basically going to be a transition clip to put between a first play video and the main menu on a DVD (for less abrupt, more smooth transition b/t the two). Is there something like an image to mpg converter?? Couldn't find after search..
2. Join the first play clip and the new clip created in step #1 to create one new first play clip
Can someone help? Thanks..
Slide Show Movie Maker .... will convert jpeg etc to .avi
check it out here http://www.joern-thiemann.de/tools/SSMM/index.htm
l
.... you could then convert it to mpeg with TMPGenc or similar .... TMPGenc will also join the resultant mpeg to your original first play mpeg -
Thanks, psx_pirate.. that helps. But still curious if there's anything that will make the slide show and convert to mpg/m2v.. ??
Create an AviSynth script using the ImageSource command and load that script into an MPEG encoder like HCenc.
Ulead DVD Slide Show does the job very well. I got it free with a 50 disk DVD-R cake box. It permits a huge number of images to be put on the DVD. The application takes the images and converts them into MPEG before creating the VOBs.
DVDLab has got similar facility. In addition it permits mixing of normal DVD-Video with slide shows.
Go to the site of each software for more details.
VirtualDub commandline - AVS to BMP/PNG/JPG
By wiseant in forum Video ConversionReplies: 0Last Post: 10th Mar 2012, 17:01 -
How to Save JPG / BMP output from *.swf files?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 14th Oct 2010, 02:32 -
Adding Bmp/Jpg to Flav
By Soixante in forum EditingReplies: 0Last Post: 11th Jan 2010, 14:54 -
DVD Flick importing jpg/bmp
By Soixante in forum Authoring (DVD)Replies: 2Last Post: 19th Sep 2009, 14:19 -
Converted analog film movies to BMP/JPG: now to AVI and then DVD
By Wimpie44 in forum Newbie / General discussionsReplies: 13Last Post: 1st Jul 2007, 12:47
