    Aug 2006
    When I try to compress a 1.26 GB iso file to .rar into split volumes (WinRAR), about 49mb each, always the last file is corrupted. What's causing these problems. Tried atleast 10 times with no luck. Tried it with normal and best compression, still no luck.
    I've tested it on smaller files but they were okay.
    I've got a 2.66 ghz and 512mb of ram.
    Please help. thx.
  2. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    Contact the company that sells Winrar, I am sure they can help you with this?
    Have you checked your harddisk for bad sectors?, is your machine overclocked?
    No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
  3. Member CrayonEater's Avatar
    May 2006
    Try running Scandisk (well, really, "Error-Checking") on your disk. Let's just rule out bad sectors.
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Just because I'm curious: How are the files corrupted?
