After a multitude of problems editing out the commercials from my transport streams, I've finally come to the part where I feed HDTV2DVD one large transport stream. The only problem now is that HDTV2DVD isn't filling up the entire disc, I've tried clicking "Auto-Fit" and even checking the "DL" box.
I removed the 2 other video/audio streams that I didn't want from the transport stream with VideoReDo Plus, I then cut out the segments of video I wanted with Womble Mpeg-VCR and then I merged those segments together.
The transport stream I have now is:
1 hour 9 minutes and 15 seconds
ac3 audio @ 384kbps
1280x720
HDTV2dvd is outputting to 4.02GB
I wouldn't expect it to fill up a dual layer disc, but I would expect it to fill up a single layer disc.
Is there anyway to fill up the disc, or is the size of the output set by the length of the video input?
It is the duration of the movie which is important here. About 1hour 20 mins would fill a disk...
Uploading a video to Youtube that will fill the ENTIRE youtube player.
By Clifurd in forum Video ConversionReplies: 16Last Post: 12th Mar 2010, 14:40 -
HDTV2DVD 0.4 Vista
By CathyT in forum Authoring (DVD)Replies: 2Last Post: 28th Dec 2009, 13:01 -
entire disc rip Drilbit Taylor Region1
By greenapple in forum DVD RippingReplies: 1Last Post: 13th Jul 2008, 04:09 -
Can DVD Recorder copy an entire disc?
By coody in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Jan 2008, 12:08 -
Should 16:9 video fill the entire screen on a new HD Plasma TV?
By Rkevin in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2008, 18:17
