Results 1 to 19 of 19
    Jul 2006
    India
    Hey !
    First of all, i want to appreciate this wonderful site for providing such good information.
    Problem 1 :
    I downloaded a movie from net. The movie is approximately 800MB. It is in VCD format..i.e (.DAT) format.
    The movie hangs when i fast forward it. But i am able to see the movie continously without fast forwarding it. I use WMP 11 for playing this movie. This is not the first time but it has happened many times.
    I am able to fast forward till half of the movie . But cant do after that. Then one more thing i tried to use VCD cutter 4. version but i didnt split the movie. So did this affect the video ?
    So what software should i use for optimising the video or what software should i use it to play the movie where i can fast forward it ? Or else please temm is there any other solution.
    Will the movie hang like this if i burn this movie to CD ?
    Problem 2:
    Can i convert this 800 mb movie to 700 mb so that i can burn it in 1 VCD. What software should i use for this conversion ?
    Jul 2006
    India
    i tried multiplex using TMPgenc ! but i still have the same problem...!
    I also used VCD gear and mpeg-corrector ! But no use !
    I think i did something wrong with VCD cutter only after that video is not working properly.. !
    I inserted the frame selector ( i am not sure abt the tool name) from half of the movie till end but i didnt split it. Only that part is not working while i fast forward
    Jul 2006
    India
    Also tried WINAVI....but the sound quality became worse !
    Can anyone help me please !
    If you are using the 500 Mhz. PIII that you indicate in your profile, your problem is probably because your hardware can't keep up with the data rate demands of video.
    Jul 2006
    Australia
    I've done this before.
    Use tmpgenc 3 xpress to convert vcd to mpeg2 dvd format.
    Then use nero to write a mini-dvd.
    alternatively, goto www.erightsoft.com and download superv19
    convert to mpeg1 with a lower bit rate.
    quality but works
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Could be this was originally two files joined together, but time code is messed up at the join.
    Try VCDGear. Convert the DAT to MPEG with "Fix MPEG errors" ticked.
    -- edit: I see you already did that. Or try MPEG-VCR (tools-> GOP fixer); or open the file, then save (use Z not ^S) to a new filename without changing anything.
    You may be able to fit this on one VCD disk; if you have a reasonably recent CD burner, it should be able to burn "90 minute" (800 MB) or "99 minute" (900 MB) CDRs if you can find them. If your authoring app doesn't like them, try to write to an ISO or BIN and use Fireburner.
  7. Video hangs during Fast Forwarding in WMP is a problem exists in many versions of WMP. Try other players, like winDVD, PowerDVD, and Divx players, etc....
    Jul 2006
    India
    thanks guys for ur quick replies.....! i tried mpeg-vcr but not working properly !
    But cyberlink powerdvd can play this movie better ! thanks singsing
    is there any way for reducing the 800mb to 700mb...bcoz 900mb is not available in india !
    thanks guys AlanHK, SingSing,ultramarine !
  9. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Are you sure you can't get larger capacity CDRs? Here the most common size is 800 MB.
    If you're playing it on a PC, there are many formats more compact than MPEG1, a DivX file of the same quality is less than half the size.
    Aside from that, if you're going toplay it in a VCD player, either you'll have to cut it to two disks, or edit out 10 minutes. Unless perhaps your player supports CVDs or SVCDs.
    If you're playing it on a DVD player, some of these can play DivX. Otherwise, you can make a MPEG2 with higher compression.
  10. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    Man I haven't worked with vcd in a long time but....
    As I recall you can write a 800mb vcd to a 80 minute cd (often called 700mb) but not a 74 minute one (around 654mb). The reason is that vcd have very little error checking and are written in mode 2.
    edit
    I just did a bit of checking and found this comment somewhere which explains a little better why you seem to fit more data on a vcd disc
    VCD are written in mode 2 form 2, which uses the full 2352 sectors in comparison to mode 1's 2048 sectors.
    If your vcd is under 803mb then you should not have to change it if you burn it the right way. Not as a data disc but as a vcd.
    Hope this helps
    Jul 2006
    India
    Hope this helps
    hey alanhk !
    i tried to find 800 mb cds...but is very uncommon ! so i splitted that video into 2 halves & burned it....!
    hey gll9
    burning not possible in video cd !
  12. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    hey gll9
    Why not?
    You say you have a vcd file, it is 800mb.
    I know it should fit on a 70 minute (700mb) cd.
    What is the problem in burning a vcd?
    I use Nero and when I drag and drop a file in the videocd window it gives messages about the compatibility of my files and options to convert to make them standard. If you want a non standard vcd disc (like kvcd) you can turn this off but right now all we need to see is what it says about your file.
    Do you use Nero? What software do you have for burning?
    Can you explain step by step how you are trying to burn this file.
    Jul 2006
    India
    the entire movie is 797 mb...so i guess 2hrs movie cannot be writen in 1 vcd..!
    1) First open nero
    2) then make video cd
    3) add video files
    4) it starts encoding or something like that...it becomes 1gb+...! it says it cannot be burned in 1 vcd !
    Jul 2006
    India
    can u temme how can i edit movie...? what software should i use to edit...? which is the best ?
    i want to cut some scenes to make it smaller !
  15. Do you have access to a DVD burner ?
  16. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    1) First open nero
    3) add video files
    You are not providing key information after step3
    What does Nero complain about before it starts encoding. If this was a standard vcd then it would not complain nor re-encode. The messages here are very important. Also you can turn off the option to burn a compliant vcd and it will not rencode the mpeg and it will fit on a standard 70 minute disc.
    On the first panel after choosing the option to burn a vcd 2 things can cause a problem.
    1) remove the check mark on "create standard compliant cd"
    2) Since you downloaded this public domain video, it is possible that it is not from your tv system ie... ntsc vs pal. Your selection here may cause re-encode issues.
    Like I said I'm rusty with vcd creation but this should work.
    Jul 2006
    India
    thanks a lot for patiently answering...! u are very kind !
    but my problem is not solved !
    i am uploading the screenshot of my desktop after adding the video...! it didnt encode this time...!
  18. Member
    Jul 2006
    India
    i dont have dvd burner..!if i had i wouldnt have posted this topic..!
