Hello All,
I got this wmv of PAL standard out of Photostory 3.0 but the resolution is 768x576 and DVD authoring programs refuse to accept it. I would like to make it 720x576 or 704x576. The first thing that came into my mind was Virtualdub and I downloaded Virtualdub 1.3c with ASF and WMV support but it refused to accept this wmv file. so now I am using Windows Media Studio encoder (http://www.microsoft.com/windows/windowsmedia/forpros/encoderse/default.aspx) but it is very slow. I minute video asking for 20 mins time to resize..
Anyone has better idea?
Windows Movie Maker will accept this and output a DV file at 720 x 576, if you can get it to an XP machine (although I assume you have access to this if you are running Photostory)
Read my blog here.
I will give a try, although I solved my problem in other way. I found a website, www.papajohn.org and this guy has compiled a profile for 720x576 PAL video which way crispier than the original PAL profile of Photostory.
Another issue with my Windows Movie Maker is, my OS is Swedish and I am not at all good at Swedish so it really wreaks my head.
I wonder though, why MS has screwed up so badly with both PAL and NTSC export profiles in Photostory?? -
The resolution is fine because Photostory outputs square pixels. Any decenet encoder should be able to resize this to 720 x 576 and have things look right. The two biggest mistakes that M$ made with Photostory were
a) restricting output to wmv only - there should at least be a DV avi option
b) using the same basic engine as Movie Maker, which does it's effects work and transitions at 640 x 480
Photostory is a brilliant miss - it has great features, is easy to use, is, imo, better than MemoriesonTV if you just want a video slideshow without DVD output, but it's image quality is so soft and fuzzy it negates all this.
And what's worse, M$ have taken all the best bits out of Photostory, and what's left will be built into Vista. Morons.Read my blog here.
Movie_LeftEye.wmv + Movie_RightEye.wmv + Polarized glasses = ?
By barelief in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Nov 2011, 15:45 -
combining WMV movie clips into one WMV clip
By blkwht240 in forum EditingReplies: 3Last Post: 5th Feb 2010, 00:41 -
1080p WMV to 720p WMV?
By TekMerc in forum Video ConversionReplies: 4Last Post: 7th Jan 2009, 14:41 -
Free program to resize WMV?
By pers0n in forum Newbie / General discussionsReplies: 23Last Post: 9th Jan 2008, 23:21 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 09:16
