i have two avi files that i want to burn on a dvd-r because they will not fit on a cd-r.
my standalone player supports the divx format, so there is no need to go through the hassle of converting to dvd video. i just want to burn a data dvd.
can someone please tell me a good program (besides TDA) for burning a data dvd? preferably free or trialware because i wanna make sure it works before i buy it. thanks
I use Nero since it comes with my drive. Even the Express version works just fine.
CDBurnerXP Pro
Imgburn2 can also take a folder, create an image and burn it. I haven't tested it for data only, but it should work.Read my blog here.
The right software? (dvd burning/movies/data)
By Sm12 in forum Newbie / General discussionsReplies: 1Last Post: 12th Mar 2010, 19:45 -
What burning software records a data DVD from playlists?
By Stealth3si in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2010, 23:43 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
DVD Data Burning Query
By gilera in forum Newbie / General discussionsReplies: 17Last Post: 4th Feb 2009, 04:32 -
Burning data-dvd
By btkuehn in forum Authoring (DVD)Replies: 37Last Post: 9th Oct 2008, 19:55
