  1. i have an athlon 64 3700+ with a gig of ram and two sata drives in raid zero. antec 550w power supply. completely stable system with no problems. I download wwe raw and smackdown in xvid and turn them into dvd's using your program. i just don't like watching lenghty stuff on my computer screen. prefer the couch in front of the big tv instead. anyway, raw and smackdown are like an hour and a half long. in every dvd I make, there's a high pitch sound that occurs four or five times. each time it happens it lasts about a split second. like when one wrestler slaps another you'll hear that high pitch sound instead of the slap. it's actually pretty random as to when it happens. that's just a for example. i convert the audio in every dvd into ac-3. could this be the problem? should I try to ther option. video quality is perfect with no glitches. just the sound.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    You could try using mpeg audio in the options to see if you get the same issue.
