How important is latency with DDR2 memory? Is it worth spending $195 on 2GB of dual channel DDR2 memory with 4-4-4-12 timings or should I stick with 5-5-5-12 for $165?
Nothing can stop me now, 'cause I don't care anymore.
It really depends on your system usage. In many cases, cutting off a few cycles of latency may only boost system performance by perhaps 2-3 percentage points. If your application is using small blocks of memory in rapid succession than the $195 is money well spent.
Help with long latency Silverlight streaming...
By george-at-fastsoft.com in forum Video Streaming DownloadingReplies: 4Last Post: 14th Feb 2012, 18:07 -
DDR and DDR2
By Jomapil in forum ComputerReplies: 3Last Post: 18th Dec 2008, 06:50 -
DDR vs DDR2
By CSULB71 in forum ComputerReplies: 2Last Post: 1st Jun 2008, 13:54 -
Bad memory latency
By Espen in forum ComputerReplies: 6Last Post: 26th Feb 2008, 14:43 -
question about CAS Latency
By Xylob the Destroyer in forum ComputerReplies: 7Last Post: 6th Dec 2007, 08:51
