Hi, I use ImTOO DVD to WMV converter to rip DVDs I own and put them on my PVP. They must be in WMV format. However, every DVD I rip, the audio and video are out of sync by about half a second, which is very annoying. There is an option for audio/video sync in the preferences, but this happens when I select it.
Does anyone know of
a) A way to fix this problem
or
b) A program that fixes audio/video sync issues in WMV files.
Thanks!
EDIT: Looks like I've resolved the problem. If I encode the audio in WMV9x format, it fixes the issue.
fixing 'out of sync' audio in video file
By Nonamer in forum AudioReplies: 10Last Post: 19th Feb 2011, 01:03 -
Fixing / Determining Audio Sync Issues With Only Some DVDs
By TheNut in forum DVD RippingReplies: 5Last Post: 12th Dec 2009, 17:47 -
Fixing Out of Sync Issues with Mp4 files?
By djfreex2 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 13:01 -
Fixing audio sync issues when using GOTSent to convert MKV to MP4
By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 06:56 -
Sync issues after fixing with ac3fix
By mub6 in forum AudioReplies: 5Last Post: 24th Dec 2007, 07:56
