I have recorded shows with PVR-150 with the software WinTV 2000 in mpg2 format. When i author my DVDs with TMPGEnc DVD Author and play it on a TV i notice that the field order is wrong and makes the picture look very bad... I reencoded the clip with TMPGEnc Xpress and there forced the clip to be topfield first (TMPG regoconised it as lower field) and then author it again and ofcourse the result was now perfect!
The only problem is that i dont have time to rencode it all (its about 50hours) and i dont want to do another encoding since you lose a lot of quality then. So how do i get TMPGEnc author 1.6 to realize that the files is upper field and NOT bottom field?
If its not possible to fix in that application i would like to get tips about another program that can fix it.
Hope somebody can help me
Best regards
hi
Thanks for the tip. The problem is that my files contain both audio and video wich make that impossible -
https://www.videohelp.com/tools?tool=MPEG_Video_Wizard
Had same problem keeping CC's from VHS tapes, this works.The Second Amendment:
AMERICA'S ORIGINAL
HOMELAND SECURITY -
"*sigh* Warned you, we tried. Listen, you did not. Now SCREWED, we all will be!" ~Yoda
For some reason, it appears that Hauppauge cards put something in the stream that gives everything the wrong idea of Field Order. My PVR-350 does the same thing as your PVR-150. Is there a reason why you can't just change the setting to Top Field before encoding? Everytime you record with your card you're going to have this problem, so I just change the field order setting manually before encoding because I know it's always wrong.
jman98
Check your file with GSpot or Bitrate Viewer, I think you will find they are "top field first".
Read somewhere that Analog uses "top field first" and DV uses "bottom field first".
It seems many editing and/or authoring programs are geared for video cameras,
thus the "bottom field first". Capture cards using the tuner or a VCR as inputs are
analog so "top field first". This is true of most cards that output MPEG2,
not sure about ones that output AVI. Digital TV cards may be a different story.The Second Amendment:
AMERICA'S ORIGINAL
HOMELAND SECURITY
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 16:00 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 14:37
