If anybody has any knowledge of TOTAL VIDEO CONVERTER, can they offer me advice on converting FLV files into MP4 PSP video files. i can convert no problem, but i need to create the THM. file which is a thumbnail of the video (the program just shows a black picture with the filename on it). and also i dont know how (or if it allows) to create a title to the MP4 file. it just calls the file "NO MSV TITLE TAG FOUND". really appreciate any help. cheers![]()
I've never used that program, but here's a tutorial of how to create the .THM file that may give you some ideas, at least about the format needed for the file. http://seamonkey420.tech-recipes.com/psp/custom_thumb.html
You should be able to do this with most other graphic editors, if needed. You would just grab a screenshot from the video.
Another possibility if your existing .THM is black is that your program grabbed the first frame from the video and that frame happens to be a black frame, which is not uncommon.
And you might try a different program. There are a lot of them out there if you do a Google search. Some of them are freeware also, which may work as well. -
There are plenty of free photo editors out there. I don't know about compatibility with there output formats but you can get your feet wet. I use a freebie called PHOTOPLUS by serif applications. I use version 6.0 It has many editing options. I don't have a link handy but do a net search for "photoplus" and you'll bump into it.
Flash video total bitrate
By Abstract40 in forum Video Streaming DownloadingReplies: 7Last Post: 28th Oct 2010, 12:35 -
Total Video Converter
By callmeking in forum Video ConversionReplies: 3Last Post: 14th Nov 2009, 19:51 -
I want to conver a file to FLV format. with audio aac and video as mpeg4/h2
By krishsamy in forum Video ConversionReplies: 1Last Post: 11th Nov 2009, 03:45 -
Does anyone on here use Total Video Player?
By weareone in forum Newbie / General discussionsReplies: 4Last Post: 19th Mar 2008, 13:43 -
Total Newb-Help with video to TV
By jeff7602 in forum Newbie / General discussionsReplies: 4Last Post: 28th Feb 2008, 13:20
