I'm facing a problem with tmpgenc. I export my movies in Premiere 5.1 with canopus dvraptor dv codec to an aviformat. It has a fixed framesize 768 x 576. On television (PAL) the movies look superb. Recently a friend asked me to encode a few movies to mpeg1 for use on a cdrom. I did that with tmpgenc and the quality is really good. The only problem is that the mpegmovies are stretched vertically, when played on a computerscreen (17"with windowsmediaplayer. It probably has to do with framesize. I tried every possible setting, but I can't resolve the problem. What am i doing wrong? Who can help me out?
With compliments,
Gert-Jan Remmers
If you're encoding a PAL VCD, it will be squished horizontally when viewed in a square pixel aspect ratio. You can either encode your video with a 4:3 non-VCD frame size like 384x288 or use a player like Sasami2k that supports custom aspect ratios:
http://www.sasami2k.com
-Cart
http://www.geocities.com/lukesvideo/index.html
Frame Size
By kamranj in forum Newbie / General discussionsReplies: 18Last Post: 9th Jan 2011, 18:59 -
Frame Size. What effect does it have?
By happydog500 in forum Capturing and VCRReplies: 7Last Post: 12th Mar 2009, 00:21 -
Frame size in HDVSplit
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th May 2008, 00:36 -
Video frame size
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2008, 19:35 -
How to alter frame size?
By elite123 in forum Newbie / General discussionsReplies: 4Last Post: 20th Aug 2007, 18:43
