Hi!
I'm from an other ffmpegX's Forum (www.carpo.org(French)) where a guy has a problem with mencoder. Here is the message he get :
"Encoding started on Thu Aug 31 10:35:24 CEST 2006
MEncoder dev-CVS-051126-18:35-3.3 Coffee 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec not found
CPU: PowerPC
libdvdread: Couldn't find device name.
Reading disc structure, please wait...
There are 6 titles on this DVD.
There are 16 chapters in this DVD title.
There are 1 angles in this DVD title.
DVD successfully opened.
success: format: 0 data: 0x0 - 0x8cc79800
MPEG-PS file format detected.
VIDEO: MPEG2 720x576 (aspect 3) 25.000 fps 7400.0 kbps (925.0 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400
Opening audio decoder: [liba52] AC3 decoding with liba52
No accelerated IMDCT transform found
AC3: 2.0 (dolby) 48000 Hz 192.0 kbit/s
No accelerated resampler found
AUDIO: 48000 Hz, 2 ch, s16be, 192.0 kbit/12.50% (ratio: 24000->192000)
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=352]
The selected video_out device is incompatible with this codec.
Also try adding the scale filter, e.g. -vf sHobo Tounge,scale instead of -vf sHobo Tounge.
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 576 (preferred colorspace: Mpeg PES)
VDecoder init failed Frown
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
Forcing output fourcc to 58564944 [XVID]
Building audio filter chain for 48000Hz/2ch/s16be -> 48000Hz/0ch/s8...
Building audio filter chain for 48000Hz/2ch/s16be -> 48000Hz/2ch/s16be...
VDec: vo config request - 720 x 576 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
videocodec: libavcodec (640x352 fourcc=58564944 [XVID])
1 duplicate frame(s)!
Writing AVI header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header."
He has the last version of ffmpegX, a iBook G3 500 Mhz and mac OS 10.3.9.
He get a 16kb output file...
Any ideas ?
Thanks !
apparently, mencoder is not update anymore for G3 processor....
iBook G4 1Ghz
Probably he should make sure he's using G3 binaries like these:
http://prdownloads.sourceforge.net/mplayerosx/ffmpegXbinaries230105_G3.zip?download
After Encoding Handbrake gives Error and Output video doesn't work
By ConverterCrazy in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2011, 08:36 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
mencoder : my command doesn't work
By n2turtles in forum DVD RippingReplies: 5Last Post: 2nd Jan 2010, 21:57 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
Mencoder doesn't work when called from PHP
By ApplePro in forum Video ConversionReplies: 0Last Post: 18th Jan 2008, 18:01
