I've seen several references here to capturing VHS on a camcorder.
Can anyone tell me how to go about capturing with a camcorder if you have a European DV camera that came with the analog record function disabled? I bought the "widget" that enables recording, but the record function only seems to be accessible through capture software (no buttons on the camcorder).
Any help much appreciated!
I'm at work and I don't remember the precise model number.
It's a SONY TRV***e, a Digital8 model. -
It's a Sony TRV325e (PAL).
I've tried capturing from a VCR. PAL tapes capture fine, and a good signal gets sent through the Firewire to my capture program (VideoFactory). With NTSC tapes I get audio but no video. (Both play OK on my TV.)
I'm confused. From reading around, I thought you had to disable DV-in to use the camcorder as a D/A convertor, but that's exactly what I'm getting for PAL tapes with DV-in enabled.
The main collection of tapes I want to edit is NTSC.
Is my PC up to capturing from my camcorder?
By alhenderson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 21st Sep 2009, 03:54 -
Capturing from DV Camcorder
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2008, 00:16 -
Question about color space using a DV camcorder for capturing VHS
By binister in forum Newbie / General discussionsReplies: 16Last Post: 12th Jan 2008, 19:14 -
Does capturing with a camcorder really damage it?
By IL_video in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 22nd Nov 2007, 10:31 -
Capturing from camcorder
By Confused Chimp in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 14:09
