I captured lots of small videos, from different channels, and now I wanna put them all in one DVD.
I usually demultiplex the video (mpeg2 directly captured) to m2v and mp2 files. Then I encode the mp2 to one mp3 and one wav file. I use MP3Gain to check the volume on the mp3 file then I lower/raise the wav file on Adobe Audition. Then I normalize it.
The problem is that it works fine when I capture from just one channel. As I captured from 2 or 3 different channels the volume of each file varies a lot.
Is there a simple way to make all the wav files the same volume easily, so I don't have to encode all as mp3 to check the volume and raise/low in Audition?
Hope I stated myself clear.
Bruno
One option would be convert all mp2 files to mp3. Load all on MP3Gain, set the db level I want, and go for it. Then encode to wav.
I don't quite understand your methodology here? Perhaps Audition's "Group Waveform Normalise" is what you're after? Just check Audition's help files for "batch" processing.
I didn't try the "Group Waveform Normalize" because I didn't know how it would work. I don't know if it normalizes the file considering the peak levels on this particular file or it compares with others.
I tried here, seems to have worked ok.
Thanx for the reply.
Adjusting volume of video files
By pooksahib in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2011, 14:48 -
Same volume for several video files!
By martinjamming in forum Newbie / General discussionsReplies: 4Last Post: 29th Jan 2010, 20:16 -
Low volume on flv files
By drwho in forum Video ConversionReplies: 3Last Post: 22nd Jul 2007, 18:13 -
Daytek DVR-P30: lots of 'fails' when erasing, lots of nothing when recordin
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Jul 2007, 16:43 -
.avi files -- Help I'm burning lots of DVD blanks...
By TorreyGuy in forum MacReplies: 6Last Post: 11th Jul 2007, 08:58
