Probably not. SUPER is fairly limited on settings. But it does use standard encoders and you may be able to use command line settings with them. They are listed at the top of the SUPER window. If it's mencoder, look to the left in 'Tools' and you should find it. MPlayer / Mencoder.
What did you set for output size in your bitrate calculator? That sounds like a 700MB output size for a 8 minute video.
Do you really want it that big? A 100MB file would be a little over 1000kbps and probably still way more than needed to achieve the same quality as your .flv video.
SUPER conversion question...
By mjl1297 in forum Video ConversionReplies: 9Last Post: 7th May 2011, 15:17 -
SUPER - DVD Conversion?
By MVW in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2010, 16:02 -
Super : conversion issue with audio
By Jettto in forum Video ConversionReplies: 1Last Post: 14th Oct 2009, 02:21 -
Bitrate and Video Conversion with Super
By Excelsior123 in forum Video ConversionReplies: 1Last Post: 28th Mar 2008, 22:03 -
mp4 conversion with super bitrate?
By m-man in forum Video ConversionReplies: 4Last Post: 13th May 2007, 01:02
