I just downloaded and installed the demo. I am very impressed and am seriously thinking of buying.
I am new to this forum, so please bear with me.
I have looked for posts regarding ability to insert text. I went back into 2005 and the issue was discussed but I wasn't able to find an answer so, I will pose my question: Are there future plans to encorporate text capability for the menu? I would like to be able to insert text using a text box and text tool. Right now, if I understand the program correctly, I am restricted to modifying the menu name and modifying the various file names. I would like to be able to insert (e.g.) date of film, length of film, director, actors, etc. Thank you. I am impressed with your program.
At the moment, the only way to do what you want is to edit the background image in a graphics program (paint, paint shop pro, photoshop for example) and then load it up as a menu... but yes i can see that feature being added in the future.
WD TV capability
By jayantadak in forum Media Center PC / MediaCentersReplies: 2Last Post: 26th Apr 2010, 23:00 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 09:54 -
Does this mean I have Firewire capability?
By gom in forum Newbie / General discussionsReplies: 7Last Post: 22nd Jun 2009, 04:00 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 11:38 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 16:50
