Can someone please tell me the options I have for watching DVDs played on my PCs DVD player on my television? The graphics card in my PC is a Radeon X300 and I think it only has a DVI out connector and the television I want to hook it up to only has composite inputs. Is there such a thing as a DVI to composite adapter? I looked on-line but could not find anything. Do I need to get a new graphics card, perhaps one with S video out? I have seen S video to composite video adapters available online. Or, could I do this with a TV tuner card?
Also, when hooking up a set-top DVD player to a TV using composite cables, how long can the cables be before there is a noticeable degradation in picture quality? Thanks!
For the computer playback option you need a new graphics card with composite out.
Or you need a new TV with component analog inputs (assuming the X300 allows YPbPr output options)
Why not just go to Walmart and buy a $30 (on sale?) DVD player with composite out? Then you can use the computer while playing a DVD. It won't be progressive or high quality, but then neither is your TV.
Two internet connections on same PC
By sohaibrazzaq in forum ComputerReplies: 4Last Post: 2nd Jul 2009, 10:17 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 10:55 -
870801 - watching DVDs by vlc
By hamidi2 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2008, 23:20 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 21:19 -
HD connections?
By James in HD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 13th Nov 2007, 17:02
