I for some reason can not get Adobe Encore 2.0 to stay under disc capacity for a 4.7 dvd.
I have taken every video asset out and it said I had 4.66 gb of free space. So I used TMPEGc Xpress to convert and changed the compression to only take up about 3.9 gb of space on a 4.7
Whenever I import it into adobe and link to buttons it reaches 4.78 and says it's over disc capacity in the Check Project task.
Is there a way to get it under???????????
It maybe wants to reencode the audio(to uncompressed pcm)? Check audio compressions settings in encore.
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 05:46 -
Adobe Encore question...
By sdsumike619 in forum Authoring (DVD)Replies: 18Last Post: 5th Aug 2009, 00:58 -
Adobe Encore Help
By Entengdigital in forum Authoring (DVD)Replies: 0Last Post: 17th Jan 2008, 02:36 -
adobe encore question
By meshnut in forum Authoring (DVD)Replies: 5Last Post: 5th Dec 2007, 15:53 -
Adobe Encore 2.0 Soundtrack Question
By Davecore in forum Authoring (DVD)Replies: 6Last Post: 5th Aug 2007, 22:03
