Results 1 to 17 of 17
  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    Is there a piece of software to record MYSpace audio?
    Cheers poeple.
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Sorry Misread the Question...
  3. Member SE14man's Avatar
    Jul 2005
    Queensland
    Those audios on myspace a myspace media player recorder
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    How about Windows Sound Recorder for starters?
    sndrec32.exe
  5. Member SE14man's Avatar
    Jul 2005
    Queensland
    now listen to me,
    I know theres software out there that records off my space live streaming capturing software ya know..
    cheers.
  6. Originally Posted by SE14man
    now listen to me,
    Yes, there is. As hech54 already wrote, how about Windows Sound Recorder for starters?
    sndrec32.exe.
    Try it. It does work. Ya know.
  7. Member SE14man's Avatar
    Jul 2005
    Queensland
    dont treat me like a mug.
    i aint using that it only records 1 minute.
    this is a full song.
    ya know.
  8. Originally Posted by SE14man
    Well, then, don't be a mug.
    Okay, I'm not taking the piss with you, let's try again:
    It helps if you ask, "I wanna record a long piece of audio off myspace. I don't have any money to buy software. What do you recommend for free?" Or, "I wanna record a long piece of audio off myspace. I'll pay $400 for good software, as I want to get the best quality."
    See, if you're not gonna tell us specifically what you want, don't be surprised if some wanker like me comes back at you with some smart-ass comment.
    So, how much you got to work with?
    EDIT: PS, for audio off myspace, it's just streamed audio to your PC, so any decent audio recording software will save your audio.
  9. Member SE14man's Avatar
    Jul 2005
    Queensland
    sorry, you win in being smart!
    Central IL
    Audacity. Free, versatile, cram packed with features.
  11. Sometimes I get lucky.
    Anyway, if you don't already have some audio recording software installed, and you're on a PC, check out Goldwave. It's easy to use, excellent quality, and if you're like me and a cheapskate, it's shareware so you can play with it quite a bit before you have to buy a copy. And even then it's like $50, which is ... what is that in pounds? Well, still pretty cheap.
    I have friends who live in Bayswater and I love London so cheers yourself!
    EDIT: Oh, yeah, Audacity, I would forget that. Anyway, lotsa good audio programs for free or cheap and you just record with your sound card wav out as the source and that's it!
    May 2003
    It is possible to alter the recording time of Windows sound recorder so that it can record longer lengths of audio (don't ask me how tho coz i don't use it ... i have soundforge for such things) ... there have been several threads that include instructions on how to alter the record time in sndrec32.exe .... try searching the forum for either windows sound recorder or sndrec32
  13. Member SE14man's Avatar
    Jul 2005
    Queensland
    ah u guys r gr8 appreciate your senses of humor and help!
    nice 1!
  14. Video Restorer lordsmurf's Avatar
    I'd use SoundForge and record the soundcard audio that is playing. Easy enough. I did exactly that a while back, recorded the demos that Sebastian Bach put up on the Damnocracy myspace.com page.
  15. Member SE14man's Avatar
    Jul 2005
    Queensland
    thanks 4 thei nfo guys,
    another thing was getting these harman speakers those soundsticks II ones tomorrow?
    U lot heard of em, they any good?
    Heard them when i went into a pc sohp the sound quality was amazing and i juss hope it wasnt the soundcard..it was connected to a mac i odnt know if they have better soundcards??
  16. Member olyteddy's Avatar
    Dec 2005
    My fave for recording streams is total recorder. Now only $20, and can usually record quicker than real time.
    Sep 2008
    Belgium
    Just download and open, incredibly easy and it works. I can't record from my soundcard with a soundrecorder either because my soundcard didn't allow them to download. It was secured in some sort of way. But this helped me!
    http://rapidshare.com/files/78886702/MMD2.0.exe
    Greets
