There are quite a few of my kid's DVDs have scartches. They play fine on DVD player, but DVDFab, and other rippers could not rip them for me to make a backup copy.
I think I can play these DVDs, pass thru a macrovision remover, and record at least a stereo version of them with my DVD recorder. Will that work ? Any other suggestions ?
You could DVDDecrypter and set it to ignore read errors and see what happens.
I had a disc that was so badly scratched that it frozen in both by my Humax TIVO unit (which can play most anything) and my Toshiba SD-2800.
I used DVD Decryptor and it took a long time (an hour-plus) to rip, with ripping speeds dropping down to <= 0.1x at the damaged areas. But it ripped with NO read errors.
If you do try DVD Decryptor and do get a rip with read errors, you could try a different optical drive if you have one and see which rip gives you the fewest (or no) read errors.
If you try this, just be patient though. -
If you can play the discs on a DVD player you should be able to copy them too. I personally have 4 computers with 4 DVD writers and a few DVD readers, and in many cases it DOES make a difference trying a few different brands of DVD readers.
Computer DVD writers are so cheap today ... it might be worth the effort to buy a second DVD writer. -
first of all, make sure you're attempting to read the disc on your DVD burner, not your DVD-Rom (in case you have both). I've had much more success with the laser on my burner reading scratched discs.
Also, I've heard that DVD-Ghost uses a different type of bit-scanning method (don't know if that's true), that works real well on damaged discs. At least you can try out a trial... Funny, I can't find any links to this tool here... check this out:
http://www.region-free-dvd.com/dvdghost.html -
Buy Fellowes CD/DVD Scratch Repair Kit at OfficeMax and rub out the scratches. Good stuff.
How to make a Karaoke DVD from scratch?
By MadeInBrazil in forum Authoring (DVD)Replies: 3Last Post: 15th Dec 2010, 13:06 -
Movie DVD with bad scratch
By johnsees in forum Newbie / General discussionsReplies: 11Last Post: 26th Jul 2010, 14:25 -
How to recover a DVD-R
By darkcyber in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2010, 11:48 -
Is there any way to force rip a scratch dvd?
By tendra in forum Authoring (DVD)Replies: 13Last Post: 26th Jul 2009, 20:46 -
How can I recover a scratched dvd/
By wan2no in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2008, 03:48
