Basically i have chinese subtitles in .srt format that wont display correctly and comes up with symbols and random gibberish. If i open it with MS Word, i get an option to encode in GB2312 and then it is readable
How would i change it so the subtitles are readable?
You need to use the correct character encoding when decoding or encode as unicode/utf-8.
Chinese subtitles require Chinese font on the computer?
By Haopengyou in forum SubtitleReplies: 0Last Post: 24th Mar 2012, 12:04 -
unreadable greek subtitles
By ioakim in forum SubtitleReplies: 8Last Post: 12th Mar 2012, 08:45 -
How to I convert Chinese srt to HD subtitles?
By TetsuSama69 in forum SubtitleReplies: 4Last Post: 31st Dec 2010, 18:58 -
By ioakim2an in forum SubtitleReplies: 1Last Post: 17th Aug 2010, 06:52 -
subtitles showing like chinese
By forare in forum SubtitleReplies: 1Last Post: 20th Aug 2009, 09:20
